mss28
I have a renovation and alteration school project where existing deck form is paper reinforced wire mesh (steeltex) placed over 16" deep steel joists. See attached. I presume this concrete form to be a combustible material. Upright sprinklers are provided in concealed ceiling cavity for most of the spaces. There is general music room above which an acoustical ceiling (consisting of 2 layers of gypsum and batt insulation) is attached to bottom of steel joists with isolation hangers. The ceiling covers all perimeters of the room. There is only sprinkler piping above this acoustical ceiling running through joist openings and interstitial space is below this acoustical ceiling. The contractor has already installed acoustical gypsum ceiling for the room. Fire marshal mentioned that the void between existing deck and acoustical ceiling requires sprinkler. Is there any way to avoid this? The ceiling has two layers of gypsum board extending perimeter walls. I am not really sure how the fire will start in this void space. Can you please advise?
Building is type IIB construction.
Thank you,
Thank you,
