In the USA the truncated domes were never tested for safety. Someone tripped on one, pitched forward face first and crushed their skull in causing permanent disability. Doctor said it was as if she were hit with a ball peen hammer.I found these in Lithuania last week while on vacation. Most of the domes were built into the pavers that made up most sidewalks. Have you seen any like these in the US?
I am pretty confident the concrete her head hit would have done the same thing vs a plastic truncated dome.In the USA the truncated domes were never tested for safety. Someone tripped on one, pitched forward face first and crushed their skull in causing permanent disability. Doctor said it was as if she were hit with a ball peen hammer.
That is debatable....Detectable warning surfaces shall contrast visually with adjacent gutter, street or highway, or walkway surfaces, either light-on-dark or dark-on-light.
THE PHOTO ABOVE DOES NOT PROVIDE THAT
Not by a person with neuropathy and visually impairedThat is debatable....
4.29.2* Detectable Warnings on Walking Surfaces. Detectable warnings shall consist of raised
truncated domes with a diameter of nominal 0.9 in (23 mm), a height of nominal 0.2 in (5 mm) and a
center-to-center spacing of nominal 2.35 in (60 mm) and shall contrast visually with adjoining surfaces,
either light-on-dark, or dark-on-light.
705 Detectable Warnings
705.1 General. Detectable warnings shall consist of a surface of truncated domes and shall comply with
705.
705.1.1 Dome Size. Truncated domes in a detectable warning surface shall have a base diameter
of 0.9 inch (23 mm) minimum and 1.4 inches (36 mm) maximum, a top diameter of 50 percent of the
base diameter minimum to 65 percent of the base diameter maximum, and a height of 0.2 inch (5.1
mm).
705.1.2 Dome Spacing. Truncated domes in a detectable warning surface shall have a center-tocenter
spacing of 1.6 inches (41 mm) minimum and 2.4 inches (61 mm) maximum, and a base-tobase
spacing of 0.65 inch (17 mm) minimum, measured between the most adjacent domes on a
square grid.
705.1.3 Contrast. Detectable warning surfaces shall contrast visually with adjacent walking
surfaces either light-on-dark, or dark-on-light.
