joetheinspector
- Joined
- Jan 1, 2010
- Messages
- 152
I have a stair design to access an industrial platform for infrequent maintenance access that has an approximate rise of 40 degrees from the horizontal. This design fulfills the OSHA requirements for fixed industrial stairs (OSHA 29 CFR 1910.24(e)) for the angle of the stair rise to the horizontal to be between 30 and 50 degrees.
the IBC 2003 section 1009 for the design of stair treads and risers. The IBC states that the stair riser height shall be a maximum of 7” and the stair tread depth shall be a minimum of 11”. This combination allows for a maximum of 32.5 degrees from the horizontal.
My question is, if there is an exception to the IBC to allow for greater stair rise angle for maintenance access as opposed to operational egress access as shown in the IBC Code?
