metalfab
I am confused on the stair and landing width codes. The codes imply that the landing width be the same or greater than the stair width, but there are no real clarifications of where they are measuring from. For example, we have a commercial building with a interior stair consisting of MC12x10.6 stringers that also wrap around the landing. The guardrails are 1 1/4" std. pipe (1 5/8" od) with 1 1/4" std. pipe offset handrail that is 3 1/4" from center of post to center of handrail. The wall rails are 2 1/2" from wall to center of pipe. What is the minimum stair width and where exactly are they measuring to? Also where do you measure to in calculating the landing width? Is it from the last nosing or the end of the stringers and is to the wall or the inside of the wall stringer? I would appreciate any input on this.
Thanks
Thanks
