I can only offer the way I do it. I think some things carry an expectation of performance. A stair is one of those for me. If there are two stairs, and one has compliant risers, but the other does not, I call it a deficiency. The definition for stairs is pretty open ended in both the IRC and the IBC. It would be a stretch to not consider them as stairs. If they are stairs then IRC 311.4 requires vertical egress from habitable levels to be by stairs in accordance with 311.7 and IBC 1011.1 requires that stairways serving occupied portions of a building to comply with 1011.2 through 1011.13. Neither includes limitations for "required". So beyond my expectation of performance theory, I think code may dictate they meet the applicable provisions. If it was a slide, a climbing wall or a pole, they would not be stairs by definition, nor would anyone expect them to act as such. Just the way I do it.So assuming all MOE was met without this stair, you'd allow a climbing wall, or maybe a slide or fireman's pole, but not this?
99% of the funky stair designs we see on here, I would agree with you. This one subjectively looks less "stair-ish" to me than most, which is the only reason I lean the other way in this particular case.I can only offer the way I do it. I think some things carry an expectation of performance. A stair is one of those for me. If there are two stairs, and one has compliant risers, but the other does not, I call it a deficiency. The definition for stairs is pretty open ended in both the IRC and the IBC. It would be a stretch to not consider them as stairs. If they are stairs then IRC 311.4 requires vertical egress from habitable levels to be by stairs in accordance with 311.7 and IBC 1011.1 requires that stairways serving occupied portions of a building to comply with 1011.2 through 1011.13. Neither includes limitations for "required". So beyond my expectation of performance theory, I think code may dictate they meet the applicable provisions. If it was a slide, a climbing wall or a pole, they would not be stairs by definition, nor would anyone expect them to act as such. Just the way I do it.
That's what I wonder about slides. I've seen them in contemporary churches a number of times. Could just step onto it.If you are not going to call it a stair, then is the top of what even it is an open sided walking surface? and does it need a guard possibly?
I wouldn't call it a walking surface, so I would not require a guard.If you are not going to call it a stair, then is the top of what even it is an open sided walking surface? and does it need a guard possibly?
My point exactly.Is it stairs or a series of shelves......?
Beautiful...but a little dangerous.Another. At least it's illuminated.
Don't the Codes in the Excited States require stairs to meet requirements for handrails, guards, and stairtread dimensions, regardless of whether required or not? Our codes make no distinction.Been touched on before here, but stair designs you'd have trouble getting permitted. And then if the stairs are not required, do they have to comply. I think I'd lable it a climbing wall, as it's a similar hazard.
That is the basic debate in this thread. It would be a shame to cite some of the stairs highlighted in this thread, but in most cases I would.Don't the Codes in the Excited States require stairs to meet requirements for handrails, guards, and stairtread dimensions, regardless of whether required or not? Our codes make no distinction.
I draw on my football officiating experience many times in this career.That is the basic debate in this thread. It would be a shame to cite some of the stairs highlighted in this thread, but in most cases I would.
#outlawstairs and really save lives....No wonder stairs are on the list of most accidents that happen in a home!
