Standard heat supply & ventilation for residential rooms
Lincoln
Although I have designed preliminary ductwork layouts for commercial offices using a general rule of 1 cfm per square foot, this is my first time illustrating heat supply ducts for a residence. Obviously, there is the option of Manual "D" and "J" calculations. Hmmm... I do not think I will ever use anything more sophisticated than a ductilator.
Is there another "rule of thumb" that is commonly applied to residential areas such as bedrooms and living rooms?
My main effort is to provide adequate (1) chase space and (2) spacing between floor joists and (3) headroom height in the basement. Therefore the plan is "preliminary" and it is expected that the heating contractor will apply his experience and expertise - - - after we find out who the heating contractor will be.
Again, I am wanting to know if 1 CFM per square foot of floor area is enough or too much for residential design.
Thanks
Registered Architect
ICC Certified Building Plans Examiner
I might have messed this whole thread up :( I tried moving it to the Residential Mechanical Forum.... Only moved one, tried again to make it correct, still messed up, tried to fix it again and I don't know where things are now! :banghd
So I hope you guys got what you needed out of this...
Sorry! :oops
you deleted my post! good thing I don't have much to say...
my only suggestion was to size it for flex duct.. the amount of space required for 1 cfm through rigid metal is hardly the same as flex..
I'm increasingly seeing flex duct being used where rigid once was (and probably should be) used.
Boy oh boy! I really messed this one up didn't I!!! :evil: Sorry fellers......:banghd
And you were doing so good Wayne!....Gotta issue some demerits to you! :D
