Robert Ellenberg
I read the posts concerning no longer being able to stretch cables all over the crawl space and stapleing them where the cross the bottom of the joists. As an alternative to drilling and pulling wires perpendicular to joists, is it permissable to fasten a 1x board across the bottom edges and perpendicular to the joists and then fasten the NM cable to the face of the 1x since that then provides a solid back behind the cable and prevents "hanging" anything on them? I am looking at this for use with steel joists and spacing the 1x at 8' intervals where a wire dropping from the floor above would be within 4' of one of these 1x "raceway" boards? Getting from the drop hole to the board it would be parallel to and up between the steel joists.
