ADAguy
Given a storeroom lever set with a deadbolt accessible from a corridor at a junior college
? The DB requires a key , keys are not typically accessible, so can it be approved given that access to the storeroom is limited to district maintenance staff (similar to the exception for mechanical rooms). You can exit the room from the interior as the lever would release the DB if someone inadvertantly or purposely locked it while you were in it.
