Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,388
Got a drive under basement garage constructed out of Superior Walls. They are non-combustible so the supporting walls would probably not be required to be seperated by 1/2" drywall (2006 IRC) but the closed cell foam used as the cavity insulation does require a thermal barrier/ignition barrier. The owner wants to install plywood. Did someone on this forum once write that plywood of a given thickness could provide an equivalent barrier?????
