Ensuring swimming pools are accessible to individuals with disabilities isn’t just about meeting a legal requirement—it’s about designing spaces that allow everyone to participate. The ADA lays out clear guidelines to make sure pools are inclusive, and building officials and architects play a key role in making that happen. Understanding these requirements helps avoid compliance issues and ensures that new and existing pools meet accessibility standards.
For larger pools (more than 300 linear feet of pool wall), there must be two accessible entry methods. At least one of these must be a pool lift or a sloped entry, while the second can be another lift, a transfer wall, a transfer system, or pool stairs. Smaller pools (300 linear feet or less) require just one accessible entry, which must be either a pool lift or a sloped entry.
Sloped entries (basically a built-in ramp) are another option. They must be at least 36 inches wide and have a gradual slope, no steeper than 1:12 (8.33%). These ramps should extend into the water at least 24 inches deep, and if they’re steeper than 1:20 (5%), they need landings at the top and bottom. Handrails on both sides are required, with a width between them of 33 to 38 inches.
For wading pools, the only required entry method is a sloped entry—makes sense since the water is shallow. Spas must provide at least one accessible entry, which can be a lift, transfer wall, or transfer system.
Understanding the ADA Requirements for Pools
The ADA requires that public pools and commercial facilities provide accessible entry and exit options. These rules apply to both new pools and alterations to existing ones. The key point is that pools must have at least one or two accessible means of entry, depending on their size.For larger pools (more than 300 linear feet of pool wall), there must be two accessible entry methods. At least one of these must be a pool lift or a sloped entry, while the second can be another lift, a transfer wall, a transfer system, or pool stairs. Smaller pools (300 linear feet or less) require just one accessible entry, which must be either a pool lift or a sloped entry.
Breaking Down the Different Accessible Entry Methods
Pool lifts are one of the most common solutions. They need to be installed where the water depth is 48 inches or less unless the entire pool is deeper. The lift must be operable from both the deck and water, meaning a person with a disability should be able to use it independently. Controls have to be simple—no twisting, pinching, or tight grasping required—and must work with no more than five pounds of force. The seat must be at least 16 inches wide, with footrests required for stability. It should lower users into the water at least 18 inches below the surface, and the lift itself must support at least 300 pounds.Sloped entries (basically a built-in ramp) are another option. They must be at least 36 inches wide and have a gradual slope, no steeper than 1:12 (8.33%). These ramps should extend into the water at least 24 inches deep, and if they’re steeper than 1:20 (5%), they need landings at the top and bottom. Handrails on both sides are required, with a width between them of 33 to 38 inches.
