Switch box in contact with 1-inch clearance B-vent flue
SCBO1
MID WEST
Doing a rough-in inspection and came across a white switch box making contact with a B-vent flue. First thought was you can't do that! So I have been trying to find if it is permitted?
The 1-inch clearance for the B-vent flue is to combustibles. If this box was non-metallic or Bakelite would it be allowed to touch the flue?
What about if the box was PVC? I would think this would not be allowed.
The NEC would probably require high-temperature insulation on conductors and possibly oversizing the conductors for a high ambient temperature.
Hopefully the manufacturers instructions require separation from B-vents and other high temperature items.
Allied Moulded #434 Fiberglas switch box touching a 1-inch clearance B-vent.
  • Standards:
    ANSI / UL 514C: File No. E30594
  • Fire Classification:
    Fire Test of Building Construction Materials
    ANSI / UL 263: File No. CEYY.R9379 (Category / File No.)
    Note: Products must also be certified to: ANSI / UL 514C
    Fire Resistance Classification in Wall Assemblies 2-Hours or less
    Shall be separated by a horizontal distance of not less than 24 inches
    Note: For more details please refer to the UL fire resistive directory and Allied Moulded’s CEYY.9379 (Outlet boxes and fittings classified for fire resistance)
