(Add) 1011.1.2 Accessible exits. Where exit signs are required by Section 1011.1 of this code, accessible exit doors at the level of exit discharge that lead directly to accessible paths of exit discharge shall additionally be marked by the International Symbol of Accessibility. Such symbol shall be not less than 6 inches high and shall be incorporated into the required exit sign or shall be located directly adjacent to it. Such symbol shall meet the requirements of Section 1011.
1011.3 Tactile exit signs.
A tactile sign stating EXIT and complying with ICC A117.1 shall be provided adjacent to each door to an egress stairway, an exit passageway and the exit discharge.
(Amd) 1110.1 Signs. Required accessible elements shall be identified by the International Symbol of Accessibility at the following locations:
1. Accessible parking spaces as required by Section 1106. Pursuant to subsection (h) of section 14-253a of the Connecticut General Statutes, such spaces shall be designated by above-grade signs with white lettering against a blue background and shall bear the words “HANDICAPPED PARKING PERMIT REQUIRED” and “VIOLATORS WILL BE FINED” in addition to the International Symbol of Accessibility. When such a sign is replaced, repaired or erected, it shall indicate the minimum fine for a violation of subsection (f) of section 14-253a of the Connecticut General Statutes. Such indicator may be in the form of a notice affixed to such sign.
2. Accessible passenger loading zones.
3. Accessible areas of refuge required by Section 1007.6.
4. Accessible portable toilet and bathing units.
5. Accessible means of egress stairways.
6. Accessible toilet or bathing rooms where multiple single-user toilet or bathing rooms are clustered at a single location.
7. Accessible entrances where not all entrances are accessible.
8. Accessible check-out aisles where not all aisles are accessible. The sign, where provided, shall be above the check-out aisle in the same location as the check-out aisle number or type of check-out identification.
9. Unisex toilet and bathing rooms.
10. Accessible dressing, fitting and locker rooms where not all such rooms are accessible.
11. Accessible grade level exits required by Section 1011.1.2.
