TAP CON for bonding jumper
codeworks
South Texas
we see our fair share of wierdness around this neck of the woods: i went to do a "meter release" this morning, and the fellow had used a tap con screw as a bonding jumper in the panel to bond the neutral, gec and panel board, wow! (bang head here, but it won't work)
codeworks,
For us "under knowledged" folks, can you please cite the applicable code section that your
application violates ( either the IRC and or the NEC )? I'm not familiar with the term
"tap con" screw!
Thanks!
globe trekker said:
codeworks,For us "under knowledged" folks, can you please cite the applicable code section that your
"tap con" screw!
Thanks!
250.8(A) NEC.
A tap con concrete screw does not meet the requirements for bonding connections.
Chris
What is the application? Was the tapcon used to mount hardware? This thread needs a picture.
I could see that one being pulled over on an inspector, some times its hard to see the color difference from tap-con blue and grounding screw green in a dark basement?
Good catch codeworks, thanks for the heads up!
pc1
What "blue paint"? Isn't the color manufactured in to the screw itself, or
is the color applied post-manufacuring, ...in some type of metal
anodizing process?
In the ES Report, in Section 5.9, ..the tap con screws are restricted to
"dry, interior use only".
globe trekker said:
What "blue paint"? Isn't the color manufactured in to the screw itself, oris the color applied post-manufacuring, ...in some type of metal
anodizing process?
Tapcons are coated with a blue Climaseal® coating. This coating provides exceptional corrosion resistance.
So, if the subject "tap con" screw did not have the coating removed, it would
fail on two counts in the indictment. (1) the coating is a barrier to an
effective bonding connection, & (2) the "tap con" screw is not listed for
exterior applications. ;)
