We don't either, as a departmental policy. If the structure will be used for sales, then we kick Chapters 10 & 11 in.mtlogcabin said:We do not permit or regulate trailers on construction sites. The steps leading to and from the trailers are what they are
I agree PaulPaul Sweet said:The stairs have to meet OSHA, but that's somebody else's headache.
The job trailers I visit are usually attended by Developers, RDP's, Code Officials, Business CEO's and Contractor's..and in short all site visitors must report to Job Trailer. Only about one third of those at the monthly meetings are adept at, or capable of, climbing up and over partially built and unbraced structures. While I agree with others, it is primarily an OSHA concern, there is a point to discussing a threshold at which point a minimum standard could or should be considered.High Desert said:You have contractors crawling all over partially built and unbraced structures. I wouldn't worry about the rise and run of the stairs. If they can get up and down a ladder, I'm sure the job shack stairs are not much of a challenge or safety hazard. We don't even look at them.
But not the publicPapio Bldg Dept said:The job trailers I visit are usually attended by Developers, RDP's, Code Officials, Business CEO's and Contractor's..and in short all site visitors must report to Job Trailer. Only about one third of those at the monthly meetings are adept at, or capable of, climbing up and over partially built and unbraced structures. While I agree with others, it is primarily an OSHA concern, there is a point to discussing a threshold at which point a minimum standard could or should be considered.
I agree, an office trailer is not what I would consider has a job shack. Office would be a work area, are you going to say that the draftperson can't attend an office meeting because of a diability?Papio Bldg Dept said:The job trailers I visit are usually attended by Developers, RDP's, Code Officials, Business CEO's and Contractor's..and in short all site visitors must report to Job Trailer. Only about one third of those at the monthly meetings are adept at, or capable of, climbing up and over partially built and unbraced structures. While I agree with others, it is primarily an OSHA concern, there is a point to discussing a threshold at which point a minimum standard could or should be considered.
Accessibility in/to construction trailers not required as per DOJ.....TJacobs said:I consider the stairs part of the MOE but accessibility not required as per mtlogcabin.
There are no requirements.....not even a permit.For a temporary construction ofc. trailer that comes supplied with steel stairs would you require the stairs to be 100% compliant.
