Temporary stage
Yankee
New England
For one outdoor performance, does anyone require a permit (I don't know yet if it is raised or on the ground. It wouldn't be called a stage if it is on the ground, would it?)
A stage would have the hanging curtains, drops, scenery or stage effects other than lighting and sound to be classified as a legitimate stage. What you have might be a platform and not fall under the same rules. I have never addressed temporary stages or platforms in place for less than 30 days.
If it is a stage/platform on a trailer maybe not worry about it to much, ask for some documentation it hAs been built good
http://www.stagerentals.com/sl250.htm
If it is a Onsite put together stage/ platform. Might ask for a simple plan and documentation the set up is per sound practices
About how big of area are you talking about
Yankee,
While a "typical" bldg. permit may not be required for the actual platform area,
we would require a permit for any temporary electrical installations ( refer
to Article 520 & 590, in the 2008 NEC ), "IF" there are any type of electrical
power needs at / around the performing stage areas.
Yank, we don't issue a permit, but if it is in, or on City owned property, we will do inspections for electrical and placement, any life safety issues, make sure the stage doesn't impede egress.
We get an electrical permit and check electrical. As for the platform, we give them 30 days to get it moved since it is usually on a trailer and 30 days is the usual time to remove a car, trailer, etc.... if there's a complaint.
By definition what you describe does not fall under the building code requirements for a stage or platform. I would not issue a permit under the building code. Maybe an operational permit under the fire code if you want to have some input on the event.
2009 IBC
PLATFORM. A raised area within a building
STAGE. A space within a building utilized for entertainment or presentations,
Thanks all (yes, even you Brudgers : ). . .
It is public property and they have an Event Permit issued by the BOS, , one extension cord to the music player, only the ballerina on the stage, guess I'll leave it alone!
Yank
What time does music player play for you to dance?? Is your tutu ready??
Sounds like a very small platform 30 by 30 or so????
From the 2008 NEC:
Article 520 - Definitions.
Performance Area.
"The stage and audience seating area associated with a temporary stage
structure, whether indoors or outdoors, constructed of scaffolding, truss,
platforms, or similar devices, that is used for the presentation of theatrical
or musical productions or for public presentations."
Yes, here, we would require a permit for that extension cord! Refer to Article
210.8(B)(4), in the 2008 NEC.
Well in RI we do sometimes.
When its the Newport Jazz Festival / FOlk Festival in an open air Fort "ADAMS" park
basically due to size, exposure, and the fact that it usually is a conopy type stage structure.
we make sure its anchored, secured and together, and we also require the electrical permits.
at other times on the statehouse lawn or park in front we do not require building but always yes on electrric
smaller shorter term 1 day event why one and not the other is a wonderment.
Access to Temporary stages
In the ADA, both Title II and Title III entities must now provide an accessible route that directly connects the accessible seating and the stage.
2009 IBC SECTION 108 TEMPORARY STRUCTURES AND USES
108.1 General. The building official is authorized to issue a permit for temporary structures and temporary uses. Such permits shall be limited as to time of service, but shall not be permitted for more than 180 days. The building official is authorized to grant extensions for demonstrated cause.
108.2 Conformance. Temporary structures and uses shall conform to the structural strength, fire safety, means of egress, accessibility, light, ventilation and sanitary requirements of this code as necessary to ensure public health, safety and general welfare.
108.3 Temporary power. The building official is authorized to give permission to temporarily supply and use power in part of an electric installation before such installation has been fully completed and the final certificate of completion has been issued. The part covered by the temporary certificate shall comply with the requirements specified for temporary lighting, heat or power in NFPA 70.
PLATFORM. A raised area within a building used for worship, the presentation of music, plays or other entertainment; the head table for special guests; the raised area for lecturers and speakers; boxing and wrestling rings; theater-in-the-round stages; and similar purposes wherein there are no overhead hanging curtains, drops, scenery or stage effects other than lighting and sound. A temporary platform is one installed for not more than 30 days. (rules of grammar... the semi-colons divide the requirements. The only things listed that the "...within a building..." applies to are "... used for worship, the presentation of music, plays or other entertainment;" All other items listed are not required to be 'within a building'.)
We permit and inspect them, sometimes on a building permit and sometimes on a festival permit.
In addition to electrical issues include accessibility and structural. Yes a ramp is required and often find missing connections.
