Test the moderators
This is only a drill. Since we should have little to no reason to moderate we will probably get out of practice.
Can a moderator of this topic please take care of this post.
Remove the following sentence.
Re: Test the moderators
Is there some way to get to the Moderator Control Panel (MCP)? Ooops...just saw it in the reply section.
I'm still reading up on the Documentation stuff you sent us.
Thank you. At least now I know that the moderators permissions work now. Before I had no idea if it worked. I only knew that I assigned permissions. Thanks!
How about a test moving a post to where it should be posted?
This one...
http://inspectpa.com/phpbb/viewtopic.php?f=1&t=92
is in Commercial Building and should be in "Off Topic".
Sorry not picking on the moderators, but this is the kind of stuff we need to do to keep the forums clean and the topics posted where they should be! Please don't get mad! :)
And how long are you going to give them before they get a failing grade? :roll: :D
Jeff, I would like to move this post to "off topic's". It should be easy. I need to learn and use the tools provided. JP
Wouldn't test the moderators be more appropriate under Website Discussions? :?
Woo-hoo, do I get a prize? I think I moved the Jyoti thread from Commercial to here!
TJ, You may be right. I would like to test some of the other tools available. I will move this to website discussions but I want to try the "split" tool just to see. I hope that I do not wreck this thread and that Jeff will be able to follow. JP
Well, No need. All the tools are really stright forward and very easy to use. :P I'll just leave it here. This site is VERY easy to navigate. :P Good job Jeff. JP
