The 3 Types of Accessible in the 2023 NEC
To start things off, let's look at all three definitions.
Accessible (as applied to equipment).
Capable of being reached for operation, renewal, and inspection.
Accessible (as applied to wiring methods).
Capable of being removed or exposed without damaging the building structure or finish or not permanently closed in or blocked by the structure, other electrical equipment, other building systems, or finish of the building.
Accessible, Readily (Readily Accessible).
Capable of being reached quickly for operation, renewal, or inspections without requiring those to whom ready access is requisite to take actions such as to use tools (other than keys), to climb over or under, to remove obstacles, or to resort to portable ladders, and so forth.
In the 2023 National Electrical Code, "Accessible" as applied to equipment takes a specific meaning that is crucial for safe and efficient electrical maintenance. Defined by Code-Making Panel 1 (CMP-1), it denotes that equipment must be capable of being reached for operation, renewal, and inspection. This definition is pivotal in ensuring that critical components like switches, circuit breakers, and busway installations are not hindered by inaccessibility. It allows for routine checks and emergency interventions, safeguarding both the equipment and the personnel handling it. The NEC outlines this in specific sections, such as 404.8(A) for switches and circuit breakers, and 368.17(C) for busway installations, ensuring a practical approach to electrical safety.
The term takes on a slightly different nuance when applied to wiring methods. In this context, "Accessible" means that wiring methods should be capable of being removed or exposed without damaging the building’s structure or finish. It's a definition that emphasizes the balance between preserving the integrity of a building and maintaining the functionality of its electrical systems. Wiring methods, therefore, must not be permanently closed in or obstructed by the building's structure or other systems. This is particularly relevant for wiring located behind removable panels, which are not considered permanently enclosed and thus meet the criterion of being exposed, as per the NEC's guidelines. This approach ensures that electrical systems are both effectively integrated into buildings and remain accessible for future maintenance.
The third definition, "Accessible, Readily" or "Readily Accessible," is the most stringent. It stipulates that essential components should be reachable quickly and without the need for tools (other than keys), climbing over or under obstacles, or using portable ladders. This definition, crucial for quick and efficient emergency responses, does not preclude the use of locks on electrical equipment or rooms. However, it mandates that keys or combinations be accessible to authorized personnel, ensuring that while electrical hazards are kept secure from unauthorized access, they remain readily accessible to those who need it. The NEC highlights this in sections such as 230.70(A)(1) and 235.352(A), which require service disconnecting means to be readily accessible, with allowances for mechanical linkages or remote-control devices in certain industrial settings.
