Similar, but not the same at all.A similar problem can be expected as more people buy electric vehicles and want to install changing stations in their garages.
I understand what you are saying.In a condo or townhouse situation, the problem of exceeding the capacity of the service is exactly the same.
Now imagine if everyone in the building wants an electric, on-demand water heater AND a level 2 EV charging station. A level 2 charging station requires 240 volts and, IIRC, 40 amps.
We should start a new thread about EV chargers.I wasn't referring to high-rise or podium type condos, where the parking is a common or limited common element. I was referring to townhouse-style condos built under the IRC, in which each apartment or condo unit has its own garage with electricity to the garage fed from the unit's distribution panel. We have tons of these in my state and in the town where I currently work. Some are condos, others are apartments. The construction is the same, only the form of ownership differs.
We're not (yet) seeing a push for on-demand water heaters (gas or electric), but the state is heavily promoting EVs, and a couple of years ago enacted a statute requiring a percentage of level 2 EV charging station "infrastructure" in many projects. What this means is that the owners don't have to install the actual charging stations (yet), but we are required to ensure that the electrical service will handle them, the distribution panel has capacity and spare breaker spaces for them, and the conduit(s) are run from the building to the future EV charging spaces. We have already seen multiple projects on which this requirement has resulted in an increase to the size of the electric service.
