Given the 75ft 5 inches from the lowest level of FD access to top occupied floor it does meet the technical definition of a high rise building.Francis Vineyard said:Is it a High Rise?
it appears there is fd access from the bottom to the top "sloping road"Frank said:Given the 75ft 5 inches from the lowest level of FD access to top occupied floor it does meet the technical definition of a high rise building. "HIGH-RISE BUILDING. A building with an occupied floor located more than 75 feet (22 860 mm) above the lowest level of fire department vehicle access. "
If the architect wants to take advantage of the highrise provisions they could. High rise can be avoided with a fire wall.
I would think a modification to consider not a highrise as all parts of the roof are ladderable and exit travel in any stair is short would be in order.
Code reference ????hlfireinspector said:If the slope is greater than 10% the FD is going to have problems operating on it. Ladder trucks cannot set up on this slope. Fire engines will have a issue getting water from their tanks if parked the wrong direction on the slope.
OkFrancis Vineyard said:Appendix;D103.2 Grade.
Fire apparatus access roads shall not exceed 10 percent in grade.
Exception:
Grades steeper than 10 percent as approved bythe fire chief.
Did you adopt the appendix??Francis Vineyard said:Appendix;D103.2 Grade.
Exception:
Short answer yes.cda said:Did you adopt the appendix??And it is not a public street?
