Robert Ellenberg
Section P3105, Fixture Vents, under P3105.2 Fixture drains, states: The total fall in a fuxture drain resulting from pipe slope shall not exceed one pipe diameter, nor shall the vent pipe connection to a fixture drain, except for water closet, be below the weir of the trap.
I think this pipe slope not exceeding one pipe diameter refers to the distance from the fixture to the vent, including the weir but it doesn't say that--it refers to the fixture drain. You could have the vent within the prescribed distance to the weir as spelled out in table P3105.1 with proper fall, but the drain could continue for quite some distance until it joins into the main horizontal building sewer line. I would think that additional distance would be considered part of the fixture drain and it would certainly exceed a pipe diameter if it was much distance.
Am I reading this incorrectly (I think it means the distance to the vent) or is it just not well worded and it does mean the drain slope between the fixture and the vent.
