Dave Buckley
I have a request for a permit to build a tree house to live in. Looked on you tube some of these tree houses are pretty crazy with electric, plumbing and cooking. Looking for any info code or zoning.
Engineer. engineer , engineerDave Buckley said:To be used as a single family house.
Let me repeat.........mtlogcabin said:Engineer. engineer , engineerOh BTW did I mention they will need an engineer
A tree does not grow from the bottom up. If you place a sign on a tree 4 feet above the ground. twenty years later that sign will still be only 4 feet above the ground. Tree trunks and branches will get bigger in circumference and "swallow small object that are attached to them such as fence wire and electrical wiring.Hopefully a slow growing tree that way you don't have to extend your plumbing and electrical every year....
good catchJPohling said:you mean the sign will still be at the 4' level................that is correct
that might be a little troubleDave Buckley said:no info on size of lot but proposed in residential area.
