Mech
2009 IBC / IPC
I have an existing auto repair building with a trench drain emptying into a sump. I believe the sump pump discharges through the oil water separator. We are designing an addition, with two 15 ft long trench drains. I know 1002.1 Fixture traps says each plumbing fixture shall be separately trapped. So, I planned on adding a separate trap and vent line for each drain.
But after talking with my boss, I had an brain trickle.
Is there a way I can legally connect the new trench drains to the existing trench drain without the need for additional traps / vents? If the first trench drain empties into the second trench drain, can we omit one trap / vent? And if we empty the second drain into the existing drain, could we omit that trap / vent as well?
I'm thinking we need separate traps, but I thought I would ask the question(s).
I know the oil water separator is based on area drained, so please feel free to skip that issue.
Thanks
Thanks
