Triplex - can I add an interior door at the top of stairs?
mplslandlord
Minnesota
Hi, and thanks for having me on your forum! I own a triplex with one unit upstairs and two units downstairs. Currently it's like a house out of a murder mystery, as tenants could access other tenants housing without a key. Yikes! To resolve this, I've added some red lines to the floorplan where I'd like to change unit entrances.Plan:
  • Secure upstairs unit by adding locked door at top of stairs
  • Secure downstairs front unit by replacing lock on central door
  • Remove previous entry to downstairs front unit
  • Enclose hallway closet and make it a bedroom closet, converting unit to 1BD instead of studio/efficiency
Are the attached modifications valid? How would I as a DIYer ensure this modification is legit?
/monthly_2015_04/572953f2b32c5_RenovationPlan.png.aebe393b92f712ef832c45898007cae7.png
Start with your AHJ. In my AHJ the planning dept has rules. For example, covered parking is required and for a triplex; it could be from three to six spaces.
mplslandlord,
Welcome to The Building Codes Forum ! :cool:
Agree with **ICE**........You should contact the AHJ with all
plans & proposed project renovations..........They will ultimately
have approval of your project.
The Unit B ( downstairs ) appears to not have a direct egress door
from the interior [ i.e. - going thru the Laundry ].
Ask the ahj but looks good
Is it a rental place now???
One problem hate to say is that just adding a door, the ahj may want more upgrades.
There is a minimum distance for a landing which the top unit looks close. Do you know what the distance from the top step to the door is?
