Mech
2009 IBC w/ 1012 IBC Chapter 11
2000 NFPA 101 - Life Safety Code
I need to create a smoke partition with a 30 minute fire rating. There is an existing 2x4 stud wall with (1) layer of 1/2" gyp board on each side. The construction was performed in 1990; the drawings are dated January, 1990. Assuming the studs are on 16 inch centers, can I call this a 35 minute rated wall per the 2009 IBC? Or does gyp board produced in 1989 -1990 have a different fire resistance than the gyp board of today? The existing gyp board may or may not have been water resistant, if that makes a difference.
721.6.2 Walls, floors and roofs. These procedures apply to both load-bearing and nonload-bearing assemblies.
TABLE 721.6.2(1) TIME ASSIGNED TO WALLBOARD MEMBRANESa, b, c, d
[TABLE=class: grid, width: 600]
[TR]
[TD]DESCRIPTION OF FINISH[/TD]
[TD]TIMEe (minutes)[/TD]
[/TR]
[TR]
[TD]NOTE: SEVERAL
[/TD]
[/TR]
[TR]
[TD]LINES OF THIS
[/TD]
[/TR]
[TR]
[TD]TABLE WERE OMITTED
[/TD]
[/TR]
[TR]
[TD]3/8-inch gypsum wallboard[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]1/2-inch gypsum wallboard[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]5/8-inch gypsum wallboard[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]1/2-inch Type X gypsum wallboard[/TD]
[TD]25[/TD]
[/TR]
[TR]
[TD]5/8-inch Type X gypsum wallboard[/TD]
[TD]40[/TD]
[/TR]
[TR]
[TD]Double 3/8-inch gypsum wallboard[/TD]
[TD]25[/TD]
[/TR]
[TR]
[TD]1/2-inch + 3/8-inch gypsum wallboard[/TD]
[TD]35[/TD]
[/TR]
[TR]
[TD]Double 1/2-inch gypsum wallboard[/TD]
[TD]40[/TD]
[/TR]
[/TABLE]
TABLE 721.6.2(2) TIME ASSIGNED FOR CONTRIBUTION OF WOOD FRAME a, b, c
[TABLE=width: 674]
[TR]
[TD]DESCRIPTION[/TD]
[TD]TIME ASSIGNED TO FRAME (minutes)[/TD]
[/TR]
[TR]
[TD]Wood studs 16 inches o.c.[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Wood floor and roof joists 16 inches o.c.[/TD]
[TD]10[/TD]
[/TR]
[/TABLE]
For SI: 1 inch = 25.4 mm.
a. This table does not apply to studs or joists spaced more than 16 inches o.c.
b. All studs shall be nominal 2 × 4 and all joists shall have a nominal thickness of at least 2 inches.
c. Allowable spans for joists shall be determined in accordance with Sections 2308.8, 2308.10.2 and 2308.10.3.
Thanks
[TR]
[/TR]
[TR]
[TD]NOTE: SEVERAL
[/TD]
[/TR]
[TR]
[TD]LINES OF THIS
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[TD]10[/TD]
[/TR]
[TR]
[TD]15[/TD]
[/TR]
[TR]
[TD]30[/TD]
[/TR]
[TR]
[TD]25[/TD]
[/TR]
[TR]
[TD]40[/TD]
[/TR]
[TR]
[TD]25[/TD]
[/TR]
[TR]
[TD]35[/TD]
[/TR]
[TR]
[TD]40[/TD]
[/TR]
[/TABLE]
For SI: 1 inch = 25.4 mm. a. These values apply only when membranes are installed on framing members which are spaced 16 inches o.c. b. Gypsum wallboard installed over framing or furring shall be installed so that all edges are supported, except 5/8-inch Type X gypsum wallboard shall be permitted to be installed horizontally with the horizontal joints staggered 24 inches each side and unsupported but finished. c. On wood frame floor/ceiling or roof/ceiling assemblies, gypsum board shall be installed with the long dimension perpendicular to framing members and shall have all joints finished. d. The membrane on the unexposed side shall not be included in determining the fire resistance of the assembly. When dissimilar membranes are used on a wall assembly, the calculation shall be made from the least fire-resistant (weaker) side. e. The time assigned is not a finished rating. |
[TABLE=width: 674]
[TR]
[/TR]
[TR]
[TD]20[/TD]
[/TR]
[TR]
[TD]10[/TD]
[/TR]
[/TABLE]
Thanks
