Sorry not at the office so no code reference, and have seen the topic before, just have not had to deal with it.
The requirement for a wall to stay up if the other side collapses. HOw do you see this accompolished in the field???
The set up is existing building, that will be added on to, with two hour wall, and another complete building added to the existing, at the two hour wall.
Someone did not anticipate the question of collapse being asked!!!!!
It is IIB construction if that helps any. They are over allowable area with all adds already calced in.
This is what I am trying to say::: '''''The 2 hour fire wall has to be structurally independent as per 705.2
(Fire walls shall have sufficient structural stability under fire conditions to allow collapse of construction on either side without collapse of the wall for the duration of time indicated by the required fire-resistance rating.)"""""""
