Forum Coordinator
We have a permit to build 4 townhouses under the 2006 I-codes (don't ask).
Anyway, the architect who did not stamp nor does he need to stamp the residential plans as specified UL U-336 as the 2 hour separation between houses.
In the attic, his is only showing the 2 layers of 1" gypsum board with no other supporting frame or structure and he is claiming that as long as you maintain the minimum 3/4" airgap between adjacent framing, it is OK.
I cannot see any part of U-336 that would allow just the 2 layers of 1" gypsum as a stand alone even though it is in the attic area. Has anyone ever come across this set up before.
I am flagging it as incorrect for more than one reason but want to check with everyone on this. thanks
jeff
jeff
