Yikes
I evaluate a lot of older apartments for accessibility, especially if they are being used in publicly funded housing, where fundign sources (such as tax credits) have 10% of the units comply with ADA for mobility.
Many of the units have a dead-end galley kitchen with 48" between countertops. This was relatively easy to make accessible. The older codes defined a U-shaped kitchen, which requires 60" clear) as an appliance on the center of the U, and even then you could roll under the cabinets to help achieve the clearance.
However, more recent editions of CBC / ADA have defined a U shaped kitchen as anything that has 3 sides. That means that any attempt to make old kitchens like this comply with ADA will either result in moving a wall, or radically deleting cabinets to make a small L shaped kitchen.
Why did they make it more restrictive?
Does anyone have any other ideas?
