UL 300 MFG Wet Chemical List ?
CDA
Thanks for your help. Interesting the fire equipment mfg association "contact us" link does not work. I was hoping they would be able to help I guess I will have to see if the phone works!
You may choose to Refine Your Search.
Company Name
Category Name
Link to File
AMEREX CORP
Wet-chemical-solution Extinguishing System Units
GOAS.EX4658
ANSUL INC
GOAS.EX3470
BADGER FIRE PROTECTION
GOAS.EX15315
BUCKEYE FIRE EQUIPMENT CO
GOAS.EX6885
HEISER LOGISTICS INC
GOAS.EX4521
KIDDE-FENWAL INC
GOAS.EX3559
LINGJACK ENGINEERING WORKS PTE LTD
GOAS.EX16341
LVT HIGH TECH FIRE PROTECTION
GOAS.EX15622
NATIONAL FIRE FIGHTING MFG FZ CO
GOAS.EX26466
PYRO CHEM
GOAS.EX3830
click on view listing top right and the above comes up:::
http://database.ul.com/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html?name=GOAS.GuideInfo&ccnshorttitle=Wet-chemical-solution+Extinguishing+System+Units&objid=1074300868&cfgid=1073741824&version=versionless&parent_id=1073987266&sequence=1
cda said:
""""non compliant systems"""what do you mean by????
also not sure if you are looking for just wet chemical or like the PIRANHAs also??
http://www.ansul.com/en/us/DocMedia/F-9788.pdf
Manufactures had wet chemical system that are wet chemical but could not meet UL 300. In the link I sent here is an example.
All WHDR-250 & 500 (Aqua-Blue) Systems were not tested to UL-300 and are also not compliant
Kidde Fire Systems
Kidde has manufactured both Dry and Wet
Chemical Systems. Their Dry Chemical
System was not tested to UL-300 Standard
so it is not compliant. All WHDR-250 &
to UL-300 and are also not compliant. The
WHDR-450 & 900 (Aqua-Blue) systems
were tested to UL-300 Standard and are
compliant. Kidde says the WHDR-450 &
900 systems were discontinued in 1998
but that does not negate the fact that they
are UL-300 compliant. All Kidde WHDR-
260, 400 & 600 Systems (current product
offering) are compliant. The style of
Control Head does not determine UL-300
compliance.
I can install an Amerex KP375 to protect the duct, plenum and appliances, meeting UL 300. Then the cook decides to switch the location of the grill and fryer. Unless the nozzle placement is changed to meet the current installation manual, the system is no longer UL300 compliant.
What about IT&M? If the system is not serviced properly, is it still UL300 compliant?
Fire
We find so many things wrong with our reviews, making sure the agent is correct is only the first step such as...
1. They move the nozzle to clean and do not move it back into place.
2. No barrier between the fryer and the cook top.
3. Only cleaning the duct work they can reach the bottom and top and never clean in between the floors.
4. No inspection of the system.
5. Manual pull station blocked
6. Install metal shelves above the cook surface that blocks the agent.
7. Gas or electric shut valves not tested and as a result do not shut off.
8. They move the deep fat fryer so it is not under the nozzles.
9. Nozzle caps missing or my best covered with tin foil.
10. Have the inspection completed and do not repair all of the problems identified.
IT&M are part of continued compliance. The Fire Code requires systems to be maintained in accordance with...
