gojrod
I don’t understand what this means. I’m a board member of 3 story condo complex. We from time to time need to make a simple 6” cast iron repair. We would like to just no hub in ABS to the existing cast iron. Does this code prevent that. Is the code saying the TOTAL area can’t exceed two stories? Meaning the third story has to be cast iron? Or if the first story is galvanized it’s then ok for the other two to be ABS? They don’t want the total areas of ABS to exceed two stories OF AREA. So replacing small sections of a three story building is ok!? We would Not be exceeding 2/3 of the building to be ABS…Please help me clarify. And what is the intent of the law?
Thank you.
Thank you.
