Understanding Roof Recover Changes in the 2024 IRC
The 2024 International Residential Code (IRC) introduces some important updates to roof recover requirements compared to the 2021 IRC. Roof recovery refers to the process of installing a new roof covering over an existing one without removing the original materials. Understanding these updates helps ensure compliance, safety, and durability in residential roofing projects.
2021 IRC: Roof Recover Requirements (R908.3.1)
The 2021 IRC provided clear guidance on when roof recover projects were permitted:
  1. Manufacturer Instructions:
    • The new roof covering must be installed following the manufacturer's approved instructions.
  2. Independent Roofing Systems:
    • Complete and separate roofing systems, like standing-seam metal roofs, designed to transmit loads directly to the structure without relying on existing coverings, do not require removal of old materials.
  3. Wood Shake Roofs:
    • Metal panel, metal shingle, and concrete/clay tile roofs could be installed over wood shake roofs when installed in accordance with R908.4.
  4. Protective Roof Coatings:
    • New protective coatings could be applied over existing coatings or various roofing materials (e.g., metal, mineral-surfaced roll roofing, built-up roofs, modified bitumen, thermoset, thermoplastic, and spray polyurethane foam) without removal of the old coating.
Exceptions: Roof recover was prohibited if:
  • The existing roof was water-soaked or deteriorated.
  • The existing roof was slate, clay, cement, or asbestos-cement tile.
  • The roof already had two or more layers of any type of covering.
2024 IRC: Roof Recover Requirements (R908.4)
The 2024 IRC retains the core principles of the 2021 code but includes some noteworthy updates for clarity and consistency.
Key Similarities:
  • The four primary conditions for allowing roof recover projects remain unchanged:
    • Installation must follow manufacturer instructions.
    • Independent roofing systems that transmit loads directly to the structure are exempt from tear-off.
    • Installation of metal, clay, or concrete tile roofs over wood shakes remains permitted.
    • Applying new protective coatings over compatible existing coatings is allowed without removal.
Key Changes:
  • Section Numbering:
    • The section number changed from R908.3.1 in the 2021 IRC to R908.4 in the 2024 IRC. This reflects a restructuring within the roofing provisions for better organization.
  • Terminology Adjustments:
    • Language updates for better clarity and consistency, particularly around protective coatings and structural load requirements.
  • Emphasis on Structural Integrity:
    • The updated language underscores the importance of the structural system's ability to carry loads independently when using complete roofing systems like standing-seam metal roofs.
Exceptions Remain Unchanged:
  • Recover is still prohibited if:
    • The existing roof is water-soaked or deteriorated.
    • The existing roof covering is slate, clay, cement, or asbestos-cement tile.
    • There are already two or more layers of roofing.
New Section: R908.3 Roof Replacement
The 2024 IRC adds new provisions under R908.3 for roof replacement, requiring the removal of existing layers down to the roof deck with specific exceptions:
  1. Ice Barrier Membrane:
    • If an adhered ice barrier membrane is present and the sheathing is in good condition, it can remain and be covered with a new ice barrier membrane, following manufacturer instructions.
  2. Self-Adhered Underlayment:
    • If a self-adhered underlayment exists and the sheathing is sound, it may remain and be covered with compliant underlayment materials.
  3. Second Layer of Self-Adhered Underlayment:
    • A second layer is permitted if the first cannot be removed without damaging the roof deck, provided that:
      • It is approved by the manufacturer.
      • The sheathing is not deteriorated.
      • Material buildup at walls, valleys, edges, and laps does not exceed two layers.
Insights from Code Change Proposal RB281-22
This new section was introduced through proposal RB281-22, supported by the Insurance Institute for Business and Home Safety (IBHS), the Asphalt Roofing Manufacturers Association (ARMA), and the National Roofing Contractors Association (NRCA). Key insights include:
  • Reason for the Change:
    • Existing self-adhered membranes are difficult to remove, often damaging the roof deck and increasing costs. The proposal provides clear guidance on when these membranes can remain in place.
  • Collaboration and Research:
    • The change is based on over 20 years of industry observation, showing that self-adhered membranes perform effectively against water intrusion, especially after roof covering damage in high-wind events.
  • Technical Guidance:
    • The ARMA Technical Bulletin recommends removing membranes when possible. If removal would damage the deck, a second layer can be installed, ensuring laps are offset and feathered to avoid drainage issues.
  • Cost Impact:
    • This change is expected to reduce costs by avoiding unnecessary deck damage and replacement when only one layer of membrane exists.
  • Public Hearing Outcome:
    • The committee unanimously approved the proposal (10-0) with minor clarifications to manufacturer terminology.
Practical Implications
For contractors and homeowners, the updated 2024 IRC provisions mean:
  • No significant technical changes to how roof recover projects are carried out.
  • Improved clarity in code language helps reduce misinterpretations.
  • New considerations for roof replacements involving ice barriers and self-adhered underlayments.
  • Clearer guidance for scenarios involving difficult-to-remove underlayment layers.
  • Consistency with manufacturer requirements remains crucial to avoid code violations.
Pro Tip: Always verify the condition of the existing roof covering before proceeding with a recover project to avoid potential code violations and ensure long-term performance.
