Markmax33
Bronze Member
I've seen several questions about what is or isn't allowed inside of the 60' for the unlimited area buildings. I found this ICC interpretation which answers most of the those questions:
http://www2.iccsafe.org/cs/committeeArea/pdf_file/BU_00_20_03.pdf
Q1: Are structures such as tanks, cooling towers, generators, and trash dumpsters permitted within the 60-foot public
way or yard that is required to surround and adjoin an unlimited area building?
A1: Yes. An unlimited area building m ust be surrounded by a fire separation distance of not less than 60 feet. The fire
separation distance, as defined in Section 702.1, is the distance measured from the face of the unlimited area building to
an interior lot line, the centerline of an adjacent street, alley or public way, or to an imaginary line between another building
on the same property. No other building is permitted within the 60-foot fire separation distance. The purpose of the fire
separation distance is to establish a minimum separation between buildings that will serve to reduce the possibility that
a fire in one building can spread to another building. It is not the intent to prohibit elements other than buildings from being
located within the fire separation distance.
Q2: Is an autom otive parking lot permitted within the 60-foot public way or yard that is required to surround and adjoin
A2: Yes. A public way can contain a street or alley that is specifically dedicated for vehicular circulation and parking.
Vehicular circulation and parking are permitted within the portion of the 60-foot fire separation distance that extends beyond
the building property and into a public way. Likewise, vehicular circulation and parking are permitted within the portion of
the 60-foot fire separation distance that is located within the building property.
Q3: Is the 60-foot yard that is required to surround an unlimited area building required to be publicly owned?
A3: No. The 60-foot fire separation (open space) must be located on the sam e property as the building or on property
dedicated for public use. The property on which the building is located may be privately owned or publicly owned.
