Buildrightson
Hi All,
I have a question regarding unprotected openings on an exterior wall, for a residential building of many suites (R2).
What is the horizontal separation distance between the openings of a suite.
Keep in mind, between a suite, no firewall is needed. Simply a fire partition. Lets assume:
In this case, we have a 1-hour rated fire separation between suites (or dwellings), highlighted in yellow.
But I'm curious, what is the minimum distance for X, shown in red.
Please see the image here:
https://drive.google.com/file/d/1KO8b8HfqRBBmzbpL-v_fd0_V1fWbNz7l/view?usp=sharing
I often see a scenario of a firewall, where the separation the firewall must be wrapped into the exterior wall (in the presence of a balcony, or walls at an angle of 135 degrees or less):
fire wall extension at exterior wall, when balcony or projection exist
fire wall extension at exterior walls that meet at 90 degree
I appreciate any help. To be honest, I'm struggling with fire separation and how to learn the requirements. It's very difficult to interpret the rules from code, and any recommendation on where I should go to read and learn about fire separations would be a huge help!
- no buildings are nearby and the lot line is so far away that no restrictions on openings are required.
- non-combustible construction, ie concrete
- sprinklered (does this even matter to my question)
