JimmyTreeX
As the title reads: are the unvented wall-mounted gas space heaters that you can buy from Home Depot/Lowes legal primary heat sources for residential units? We run into the unvented wall heaters being used as a primary heat source all of the time, and I’m just looking for some guidance on their legality. We require that the primary heat source in a residential is either a vented gas heating unit (furnace, boiler) or electrical base board, and I’m trying to confirm if we can make an owner comply with this requirement of ours. Thank you.
