Vent spillage and more.
  • Thread starter Thread starter -
  • Start date Start date
Guest
Re: Vent spillage and more.
Is that gas piping a flex connector going through the housing of the furnace?
Insulated duct work penetrating the ceiling?
one or two issues
Sizing of vent connector to draft hood
draft hood cocked
lack of vent connector support on both
downhill run
clearance to combustibles--6" to single walled connector
single walled connector penetrating ceiling
common vent sizing?
firestop
TPR drain
sediment traps on both
ground unions on both
flex connector through cabinet
clearances to junk in room
secondary condensate drain
condensate vent
6"clearance btw connector and condensate drain pvc
elbow right off top of both appliances--should have 12"min vent rise
seismic straps
30"x36" clearance in front of furnace cabinet
Q-do you have adequate makeup air?
Otherwise, nice installs!
Hearthman
Well Hearthman that's the type of reply I appreciate.
tigerloose, do you actually see these things or does someone send them to you? Looks like the contractors in your area need lots and lots of training.
These are all pictures I have taken myself. I've been carrying a camera for about five years and many of the pictures are old. Pictures work wonders when someone calls the B/O to complain.
