    Dismiss Notice
    Dismiss Notice
Vents Thru The Roof
Discussion in 'Plumbing Codes' started by north star, May 3, 2018.
  1. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    I am seeking input from the Forum on Vents thru the Roof ( VTR's ).
    On some military plans that I have been reviewing recently, it has been
    discussed [ by some ] to NOT have any penetrations in any of the roofing
    systems.........This idea is intended to extend the life of the roofing
    systems.
    Do any of you adopt this approach ?
    Thanks for your input !
  2. ICE
    ICE Sawhorse
    7,975
    795
    We do not limit roof penetrations. I have worked a few military projects....I’m imagining ten pages on how to not penetrate the roof.
    north star likes this.
  3. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    7,108
    745
    903.5 Location of vent terminal.
    An open vent terminal from a drainage system shall not be located directly beneath any door, openable window, or other air intake opening of the building or of an adjacent building, and any such vent terminal shall not be within 10 feet (3048 mm) horizontally of such an opening unless it is 3 feet (914 mm) or more above the top of such opening.
    903.6 Extension through the wall.
    Vent terminals extending through the wall shall terminate at a point not less than 10 feet (3048 mm) from a lot line and not less than 10 feet (3048 mm) above average ground level. Vent terminals shall not terminate under the overhang of a structure with soffit vents. Side wall vent terminals shall be protected to prevent birds or rodents from entering or blocking the vent opening.
    Pcinspector1 and north star like this.
  4. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    Thanks **ICE** & **mtlogcabin** for your input !
  5. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,285
    824
    VTW.....Like MT said if you don't want the hole in the roof...
  6. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,791
    338
    Government building, "Is it hot air their venting?":rolleyes:
  7. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,050
    149
    When designing a building I try to combine vents in the attic to the greatest extent practical and minimize the number of roof penetrations, both for appearance and to reduce the number of potential leak points.
  8. mp25
    mp25 Registered User
    Jun 2, 2016
    73
    13
    I wonder if AAV would be an option under the code that you are working with - although it would be one more thing for the building engineer to worry about.
  9. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    mp25,
    I would not choose to use AAV's for venting.....I consider them
    to be mechanical devices with moving parts, that at some
    point in the future, WILL stop working !......That could possibly
    cause a detrimental effect on removal of the sanitary sewer
    gases in the lines.......Plus, diagnosing a failed AAV somewhere
    in the installed vents would be problematic [ IMO ].
    It is my intent to change the mindsets of Leadership and some
    RDP's, by removing all roof penetrations in the design and
    actual installation of the plumbing systems........It CAN be done.
    It just needs a different and compliant way to do it.
  10. conarb
    conarb Sawhorse
    Oct 22, 2009
    3,369
    242
    North Star:
    In the late 50s I took a magazine published by the NAHB, it was a nice glossy magazine that isn't published anymore. I remember an article published in about 1959 about a test house built in a tract of homes in I believe Arizona. The test house had all the vents combined in the attic into one ½" copper pipe that ran horizontally emerging through the eves, at the time the test house had performed with no problems for a couple of years, if I remember correctly the system was fought by the plumbers' unions because it would reduce work for plumbers.
  11. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,985
    267
    Hmm, chimneys still look good on buildings even if not used as originally intended.
Share This Page
