Verifying Window Compliance for Wind Loads
This question is for most of the country that is now in the 115mph wind zone per the IRC. Please exclude Florida from this conversation as this I have a handle on. The question is this. In the past the U-factor was one of the biggest concerns when looking at windows for inland areas. With the increase in the wind speed from 90 to 115 in most areas, how have you been verifying wind loads?
For example, most exposure categories in the 115mph zone will be a B or C and only a D if you are on or close to the water where you have one or more miles of open water. I see that the IRC addresses this through Tables R301.2(2) and R301.2(3) along with Section R609 and ASCE 7.
There are a lot of local window manufacturers that won't even get the energy code rating, let alone testing for the design pressures of the wind zone they are typically sold in.
Are all manufacturers having testing done and labeling or providing NOAs?
Are you guys not using the AAMA/WDMA/CSA A440/I.S.2/101 North American Fenestration Standard?
115 mph = 34 psf.
Minimum PG rating of 35. Table for US is attached.
The structural engineers wanted wind speeds that would give an ultimate design load directly, without having to multiply a working stress load by a load factor. The IRC tables multiplied the ultimate loads by a factor to arrive at working stress loads that are close to the loads for 90 MPH in earlier editions.
Sorry Jeff, I didn't realize R609 was where you were going in the other thread...We would look for the label, but we do not inspect the "rough" install. This, WRB inspections, and roof "starts" would be 3 inspections I would like to do if I had time...
