Papio Bldg Dept
Platinum Member
I am reviewing a project where the designer would like to place an unenclosed stairway around an elevator core. The project is two stories, type II-B, and an 'E' occupancy.
I have been reading through the code to determine when and where an unenclosed stairway is permitted. Section 1020.1 of the 2006 IBC seems to cover this issue, however I am unable to clarify the code language for what "remotely located" means (exception 8 & 9). I am assuming that this phrase is referring to the "distance apart" requirements for exits as defined by Section 1015.2 (as referenced to by the exceptions listed above), and not rather in some far-off out reach of the school. Is this an accurate assumption?
1020.1, Exception 8: not group H or I occupancy, max 50%, serving one adjacent floor, fully sprinklered, min. 2 means of egress, remotely located, and not open to other floors.
1020.1, Exception 9: not group H or I occupancy, serving only first and second floors, fully sprinklered, min. 2 means of egress, remotely located, and not open to other floors.
