TimNY
Just checking to see if anybody has a different interpretation of these sections.
907.10.1.1 - visible alarm devices are only required in public and common areas. Easy enough.. hallways, meeting rooms, etc. They are not required in private offices.
907.10.1.2 - You must provide wiring for visible notification devices in employee work areas that have audible notification coverage.
So visible notification devices are not required in private offices. However, since private offices are an employee work area that will have audible alarm coverage, you must provide wiring in the office for a visible notification device... that is not required?
I guess they are mandating the wiring be in place so that you can comply with ADA, even though I don't know of anyplace in the IBC that would require you to install the visible notification device if an individual is hearing impaired.
I don't have any problem with this; I think it's a great idea. But am I interpreting this correctly?
Thanks,
Tim
Thanks,
Tim
