OK so a lot has changed in the code since I first picked up an NEC in 1987. We no longer have the hard and fast rules of voltage drop. I would, however like to do something for educational purposes. Let's try to solve a problem and see who can come up with the answer based on today's codes of the 2008/2011 NEC. Here is the scenario, let's see who still has this in their memory banks. Show your work please.
You have to run a feeder to a compressor across the warehouse from your nearest, usable panelboard. The compressor has a 10HP 240 single phase motor. The distance to the compressor is 200' and the conduit will be run inside the web of the metal roof trusses. Your boss wants you to use up the THHN that he has stockpiled. Conduit size not relevant unless you want to make it relevant.
Let's see how this goes and discuss it. Please show your work so this can be educational. I wonder if we will all have the same answer.
What size copper wire THHN will you pull for this job?
