Weak Deck
In a house I just bought, I was having 3/4" hardwood installed. They staged at least 2,000lb of material on the rear deck. The deck was enclosed underneath with more stone veneer so I couldn't see the conditions of support. I commented I was worried about the load, the workers said "it will be fine" and jumped up and down and "see, it's solid". I got the load moved pretty quickly. Fast forward 3 weeks, I finally got the wall under the deck open. Glad I moved the load. Improper ledger attachment, actually can't see the connections, on the surface of brick veneer with no intermediate column support, improper joist support, concentrated load from double joists supporting an exterior stone veneer fireplace surround. And those are just the problems with the gravity load. Frankly surprised it survived. Deck repair/replacement on the horizon!
Rant...a little of topic but....
The fireplace is a wood burning unit, on a framed in and covered wood deck and roof. No hearth extension unless you count the 5/4 decking. I had a company come out to see about converting it to gas logs. In our conversation I asked if they would secure the permit. They said they didn't need a permit. I asked him if he knew why whoever did this thought it was a good idea to put a wood burning fireplace on a combustible floor with no hearth extension over a completely enclosed crawlspace blocking several house foundation vents on a deck that violates almost every prescriptive code in the book.. He said no. I said it was because they weren't required to get effing permits.
