Robert Ellenberg
I've designed houses starting back over 30 years ago and all have had the equipment in the attic, crawl, basement or occassionally the garage. I am now focused on smaller, tighter, energy efficient designs and putting all of the equipment and duct work in the condtioned space. I have also left the design of the HVAC system up to others but decided I needed to learn more so I've been studing the Mechanical System sections of the IRC which has raised some questions.
Section 13, General Mechanical Sustem Requirements, M1305.1.1, Central Furnaces, says that when they are in "compartments or alcoves", that you must have 3" of clearance on the sides and rear. However, it doesn't say how much room they must have if they are in mechanical rooms or ?? (neither can I find a definition for alcoves and compartments). But when you get to section 1402 on Central Furnaces, it says the clearance must be per the manufacturers specifications and makes no reference to location.
For access when a furnace is placed under a house, 1305.1.1 says you must have an access 30"Hx 22"W. But when you get to 1408 on vented floor furnaces it says there must be an access of 18x24.
Anyone care to give an explanation/clarification/interrpretation?
