Nicole Brooks
This is a general question, so I'm just providing a fictitious scenario. Original building is a 21,000 sf single story, sprinklered warehouse building (S-1 occupancy) (type II construction) with a 7000 sf enclosed mezzanine (business occupancy) which has two enclosed exit access stairs that lead directly outside (stair shafts not rated). What happens when somewhere along the line, the owner decides they want to subdivide that warehouse into two spaces (10,500 sf ea), by installing a full height 8" cmu wall to underside of deck. The mezzanine is fully above one of the 10.5K sf spaces. Does the mezzanine now need to be considered a second story and do the stair shafts now need to be rated? I've looked at IEBC, 802.2.1 Existing vertical openings, but they don't address mixed occupancies and I can't find anywhere in the code whether mezzanines are no longer mezzanines if the areas in which they are associated with have decreased (IBC 505.2.1 Area limitations) after the fact. What do you all think?
