LGreene
I know the answer to this question. The problem is trying to convince people of the answer. There is a section in NFPA 101 with this title, and there was a section in the IBC until the 2015 edition when it was changed to "Sensor Release of Electromagnetically Locked Egress Doors." I have been involved in code development for the electrified hardware sections so I know that the intent of the model codes is for this section to apply to electrified hardware that is released by a sensor detecting an approaching occupant. Most electrified hardware does not fall into this category - this section is mostly used for electromagnetic locks. There is a separate section that is used when the electromagnetic lock is released by hardware mounted on the door rather than released by a sensor.
I have written about this numerous times, including this recent article: http://idighardware.com/2017/07/decoded-access-controlled-egress-doors-august-2017/, but I still have people interpreting the terminology "access-controlled egress door" to mean that the section applies to doors with any type of access control reader, even though the section clearly addresses hardware released by a sensor.
Any ideas about how I can help explain the use of this section?
