What's the difference between self-closing and metered lav faucets?
Yikes
Southern California
The City of LA modified the California Plumbing Code to read as follows:
407.2.4. All faucets in public restrooms shall be self-closing or self-closing metering faucets. Metered faucets shall deliver a maximum of 0.20 gallons (0.76 L) per metering cycle.
Q1. What is the difference between a (1) self-closing faucet and (2) a self closing metering faucet?
I'm guessing that (1) is time-based shutoff and (2) is time or volume of water based shutoff, whichever happens first. But I'd like your opinion.
Q2. Is a motion-activated faucet considered self-closing? It's relying not on time, but on the action of a person moving their hands away from the sensor.
FWIW, the City of LA also added a definition of "self-closing faucet":
Self-Closing Faucet. A faucet designed to close itself as the activating mechanism is released.
So if on a motion-activated faucet proximity to the sensor is the "activating mechanism" then you could say that moving your hands away from the sensor is "releasing" the activating mechanism.
Cheers, Wayne
As to Q1, seems like it doesn't matter? The first sentence of 407.2.4 may be parsed as "All faucets in public restrooms shall be self closing OR (self-closing and metering) faucets. Which just logically reduces to "all faucets in public restrooms shall be self-closing faucets."
I guess you still have to determine if your self-closing faucet is a "metered faucet" as then the second sentence imposes a requirement you have to satisfy. For example, maybe that sentence is trying to say that the water delivered by a motion-activated faucet after you remove your hands must be no more than 0.20 gallons.
Cheers, Wayne
A "self-closing" faucet automatically shuts off after a short period of time once the handle is released, while a "metered" faucet is designed to dispense a specific, predetermined volume of water with each activation, essentially limiting the water used per use regardless of how long the handle is held open; both are often used in public restrooms to conserve water, but metering faucets provide a more precise control over water usage.
Mark, would you agree with Wayne that a touchless motion sensor faucet meets the definition of self-closing faucet?
