we are renovating an existing school. Some areas of the school are getting major renovations. the rest of the school is getting "cosmetic" changes. new finishes (floors, ceilings), all casework is being replaced and all windows are being replaced. we are also installing a full sprinkler system throughout the building and a new mechanical system. There is no change in use group.
my issue is that per current code, the building is over the allowable area (even using sprinkler increase). the building is divided into separate fire areas using 2 hour fire BARRIERS, not fire walls per 706 as required by current code. Per 3404.1 when doing alterations, you don't need to bring the entire building up to current code but i'm not sure where the line is between cosmetic updates and alterations. Is the amount of work being done require that the entire school be brought up to current code?
