bgingras
So here is the dilemma. I've built a staircase between 2 walls that don't run the full length of the stairs. The first 5 treads with no wall on the left or right, just the guard/hand rail starting at a newel The handrail/guardrail terminates into the wall ends at step 5. After the wall there are an additional 6 treads. I've seen several interpretations to the continuous handrail requirement. The first states that I can attach a handrail to the wall at tread #5 and go up from there and that the fact that this handrail does not attach directly to the handrail/guardrail from tread 1-5 doesn't matter. The other one states that I must run a handrail from the newel at the base of the stairs all the way to the top basically running it inside the guardrail so as to form a 1 piece handrail with no break from step 1 - 11. I've yet to actually see a picture of a stair built like this. Anyway, which one is correct? both? I'm also an inspector, but was taught to allow the first one. The inspector in the town I'm building in right now likes to read the code letter for letter while inspecting.
/monthly_2010_05/DSC03509.jpg.0215296c7ce2d7c72038222edab26daa.jpg
