ndaniels
Bronze Member
I have been seeing a growing amount of white thread seal tape on gas lines. I have been asking for it to be replaced since I have not found any listing approving it for use on gas lines. Here is the typical chart I find for Polytetrafluoroethylene (PTFE) is compatible with the following materials:
Water (Regular White)
Steam (Premium Pink)
Air, compressed (Premium Grade)
Alcohols (Premium Grade)
Fatty Acids (Premium Grade)
Kerosene (UL Yellow Gas)
Natural Gas (UL Yellow Gas)
Nitrogen (UL Yellow Gas)
Acids, dilute (Premium Grade)
Ammonia, liquid (Premium Grade)
Cutting Oils (Premium Grade)
Soap, Liquid (Premium Grade)
Ethylene glycol (Premium Grade)
Gasohol (UL Yellow Gas)
LPG (Premium Oxygen)
I typically get an answer from contractors that they use it every where and I need to find in code where they cant use it. I just request a listing proving that it is an approved material.
Has any one found a listing approving white Thread seal tape for use on gas lines?
Does any one else find that this is the case and is it an issue if they use the white thread seal tape with pipe dope?
