Who sees this product?
I have never seen this type of wiring assembly.
QUESTION # 1: Is this assembly approved for use
[ i.e. - by U.L., ...ESS Acceptance Criteria, ...NEC,
...NFPA, other ? ]
QUESTION # 2: Is this acceptable for installation
by boring [ i.e. - trenchless ] ?
QUESTION # 3: How does an inspector or other
test for acceptance ?
QUESTION # 4: Does this type of wiring assembly
ever get damaged and have to be removed ?
Thanks !
...NFPA, other ? ]
Thanks !
1) Yes it is UL listed and meets the ASTM standards.
2) Why not? It gets done all the time with PVC and other and this is HDPE conduit.
3) Same way you would inspect for empty or full conduit in a trench or boring hole.
4) Yeah, same as any other conduit being repaired.
Thanks Jeff for the responses !
Others may have the same questions, ...and now,
they know too !.......Thanks for sharing.
Haven't seen/heard of it, but it looks pretty sweet.
Does the price keep it competitive considering the labor savings?
I haven't seen it used yet, like FB sez, "it's pretty sweet."
Had issues in the past with contractors using different colored HDPE pipe and trying to use PVC fittings.
