fatboy
Administrator
I've been told that Section M1507 of the 2012 IRC requires whole-house mechanical ventilation. I'm not seeing M1507 as a requiring whole-house ventilation, but as the rules for if it is. Am I missing something?
Have you deciphered it yet. I do not have 2012 I codes yet but from what i can gather it is the standards for mechanical ventilation if the house has less than 5 air changes per hour as tested with a blower door at a pressure of 0.2 inches of water column or 50 pascals then the dwelling unit shall be provided with whole-house ventilation in accordance with section M 1507.3fatboy said:I've been told that Section M1507 of the 2012 IRC requires whole-house mechanical ventilation. I'm not seeing M1507 as a requiring whole-house ventilation, but as the rules for if it is. Am I missing something?
The 2012 codes are here.Gregg Harris said:I do not have 2012 I codes yet
...and the energy code requires that a dwelling unit shall have not more than 3 air changes per hour in Climate Zones 3 through 8. Thus, whole house ventilation (WHV) for all homes in zones 3-8Gregg Harris said:if the house has less than 5 air changes per hour as tested with a blower door at a pressure of 0.2 inches of water column or 50 pascals then the dwelling unit shall be provided with whole-house ventilation in accordance with section M 1507.3
You need to be able to bring outside air (make-up air) into the building.Keystone said:Can wole house ventiation be accomplished by placing a heat pump on fan mode?
Thank you Chris, but if I had your money and my time I could purchase a new set that I can print from rather than my manuals. I prefer to use manuals and highlight but when I travel it is much easier to have it digital.chris kennedy said:The 2012 codes are here.
