For deck boards?^^^ why I prefer 5/8 T & G OSB
Roof sheathing, pic taken during installation, so it is literally minutes old.Is the stamp on the top or bottom of the sheet?
Wall face or floor pic?
Dang. I thought that was a very close-up low-angle picture of deck boards.Roof sheathing, pic taken during installation, so it is literally minutes old.
H-Clips should have been spec'd out.No what?
Is it within tolerances?
Stop order?
Engineer review?
Okay to cover up?
Seems like there should be a plywood clip or blocking?
Span information should be marked on the sheeting.
Are they required by code?H-Clips should have been spec'd out.
Residential code requires it for thinner sheathing over larger spans, such as 3/8 at 24" spacing, given allowable live load and other factors.Are they required by code?
I guess that info would have helped.Whats the thickness, number of plies, span rating and actual span?
Roofers hate the clips, it makes a tear-off in the future a pain in the but.Clips suck, T&G is the way to go, I never had problems with nail holding in OSB if you don't over drive the nails
